14 minutes ago, SimonH said:
Think it's only you and me on here!!
This thing keeps going down and keeps losing my posts, so I'm having one last try then I'm giving up until it gets more stable!
Hooray we’re back up and running!
Thanks for your patience everyone. For those of you that haven’t already emailed us to ask what on earth happened, zero88.com webpages began to forward to their new home on the vari-lite.com site. However in the process, the forum was affected, resulting in extremely limited functionality. Apologies once again for the inconvenience, particularly over the festive season.
If you have any questions, as always just let us know.
Apologies if you’ve been encountering stability issues now that the forum is back up and running. We’re monitoring the forum to ensure it is functioning correctly again.
Hi All,
If you still receive "Access Denied" errors, please go into your browser's settings, and clear all cookies for the whole of zero88.com. You can then sign back into the forum, and shouldn't encounter the error again.
Please let us know if you have any questions.
Thanks for your info! I did not have anything in a hurry, so i didn't send any mails for inquiery about the forum problems.
Now I understand, and of course many thanks for solving these.
Kind regards !!
Test.
Tried to post a message elsewhere, (test & beta) didn't work.
19 hours ago, kgallen said:
Forum is still pretty messed up. I can post on occasion then immediately after I can’t edit or post again.
Sorry we're still having issues - we're trying to work out what's going on but currently we can't find the pattern. Out of interest, do you have the same problems if you use "Incognito" / "InPrivate" / whatever your browser calls it!
Dear All,
We have now implemented a change, which we believe will solve the issue with the forum, that was sometimes causing access errors when submitting replies.
If you do continue to encounter this, please send us an email to support@zero88.com
  • Like 1
I still can't reliably add comments to posts. I tried several times over the past few days to help various posters. only to receive the Access Denied response.
I logged out and in again. Didn't help.
I cleared the Cache on Chrome. Didn't help.
Hi Jon, One example of a fail for me included a reply with a link to the FLX manual (the Output Window query on FLX S, Edward has posted that link now). I don't know if having a link in my reply was part of the issue (I suspect not), but mentioning it anyway.
You've also addressed the query on move on dark not only being for position, so that one is dealt with too 🙂
