drscoop Posted November 3, 2022 Report Posted November 3, 2022 Hi, This may be a trivial thought, but is it possible to scale the font on the output window? Phantom ZerOS and, I think, our FLX S 24 shows 13 fixtures per row and I wonder if it can be scaled to show 12 per row, so each row mirrors the physical desk layout? I've seen other desks @ 12 wide and wondered how to change the scaling? Thanks! Quote
Edward Z88 Posted November 4, 2022 Report Posted November 4, 2022 Hi @drscoop Hope you're well. 12 hours ago, drscoop said: Phantom ZerOS and, I think, our FLX S 24 shows 13 fixtures per row and I wonder if it can be scaled to show 12 per row, so each row mirrors the physical desk layout? I've seen other desks @ 12 wide and wondered how to change the scaling? The Output window on the FLX S internal touchscreen is formatted to 12 fixtures wide. The Output window on external desktops is formatted to 24 fixtures wide. If you are seeing fixture number 13 top-right of your Output Window, are you missing a fixture number between 1-12? If so, fixture 13 will have bumped up a row. Hope this helps. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
drscoop Posted November 6, 2022 Author Report Posted November 6, 2022 Thanks Edward, you're right. Fixture 11 had been deleted somewhere along the line, and I'd not spotted that! 1 Quote
