penlec Posted October 23, 2022 Report Posted October 23, 2022 In the above selection I couldn't find any information on what this does (Show Fixture Section) when selected in the Zero88 manual (latest as with 7.13) or on this forum any help would be most appreciated Quote
kgallen Posted October 23, 2022 Report Posted October 23, 2022 Which console is that on? I don't recognise it as a form on FLX so maybe you're on Solution/Leap Frog/ORB? When you dialled up the on-line manual, did you select the correct console type? Quote
Edward Z88 Posted October 24, 2022 Report Posted October 24, 2022 Hi @penlec Hope you're well. 21 hours ago, penlec said: I couldn't find any information on what this does (Show Fixture Section) The "Show Fixture Section" option, is a legacy option that used to allow you to hide the parameter table at the bottom of the Output window. This option no longer functions. It is still present to indicate the setting in legacy show files. 12 hours ago, kgallen said: Which console is that on? I don't recognise it as a form on FLX so maybe you're on Solution/Leap Frog/ORB? The "Output Window Setup" option is only available on Solution and Orb consoles. This information is therefore not included in the ZerOS online manual. As @penlec has a Solution console, I have moved this topic into the Solution forum to avoid confusion. If you have any questions, please let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
penlec Posted October 24, 2022 Author Report Posted October 24, 2022 Thanks for the feedback, the Desk I am using is the Solution, one doesn't get the option of selecting a Legacy prod uct as per the screen shot attached, I looked at an old manual (IM9210 for Solution last year) it shows the window (attached) but doesn't describe the operation of the button. In the latest user manual it seems that the implementation for Legacy one cannot get at? Quote
Edward Z88 Posted October 24, 2022 Report Posted October 24, 2022 Hi @penlec 10 minutes ago, penlec said: In the latest user manual it seems that the implementation for Legacy one cannot get at? Features that are specific to Orb series and Solution series are not included in the ZerOS online manual. These features should be detailed in the original product manuals. In this instance the "Show Fixture Section" option was omitted from the Solution manual. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
penlec Posted October 31, 2022 Author Report Posted October 31, 2022 Thanks for the update Edward, although one can go through the motions of selecting it (the button changes to either red or green) it doesn't seem to change anything. I have been running OS 9.13 (after replacement of the Fader PCB) for several shows now and the only difficulty is with selecting Colour Palettes which I will raise as another topic Brett Quote
