mikeb Posted October 20, 2022 Report Posted October 20, 2022 Hi Am running 2.12 on an in-house Soulution and with a couple of LED battens created effect using the in-built effects (green sparkle) then saved it to a MFK. I then created a second effect for a couple of LED Pars, again using the in-built effects. I then recorded the second effect onto the same MFK. I changed the colour time to 0 seconds and when the fader was raised, only the second effect was output. I then deleted everything on the MFK, created the two effects together and saved them on the MFK. This worked but I felt I wanted to add some facelight so took a dimmer fader to a level then selected record and merge but once again my effects had gone. Is it me? Regards Mike Quote
Edward Z88 Posted October 21, 2022 Report Posted October 21, 2022 Hi Mike, You mention you recorded to an MFK - would you be able to confirm whether you were recording to an MFK, to store an Effect Palette, or recording to a playback, to store a cue? Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
mikeb Posted October 21, 2022 Author Report Posted October 21, 2022 Hi Edward Was storing to MFK just like I would a cue. Selected "merge" when attempting to add the changes (effect with intensity or dimmer) I wanted. Mike Quote
Edward Z88 Posted October 21, 2022 Report Posted October 21, 2022 Hi Mike, 34 minutes ago, mikeb said: Hi Edward Was storing to MFK just like I would a cue. Selected "merge" when attempting to add the changes (effect with intensity or dimmer) I wanted. Mike If you record or update an effect palette on an MFK, it will by default only include effect information. You would need to hold SHIFT and tap RECORD, to record all, and overwrite the effect palette on the MFK, should you wish to include attributes as well as effects. Let me know if you have any questions. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
