Attempted 7.13 update
I have downloaded the 7.13 update file to a usb, ensured it is unzipped and not in a subfolder - but when I attempt to view the usb from the console, I see no list of files...
Am I missing a step...? There are other files on the usb, the console sees no files at all....
Hi @Ian_p
If you tap SETUP -> Save, under "Device" you should see a removable device. If you see <No Destination Devices>, please tap Refresh. If your device then appears, you should be able to choose Load, and see the files on your drive.
Thanks Edward - for some reason the FLX does not recognise my Corsair GTX usb drive - used a different Sandisk thumb drive to get the upgrade file onto the FLX and successfully upgraded.
I used the new fixture creator to build a template for my Stairville Pro Bar 16x10w straight onto the desk - all good!!
Thanks for the pointer
cheers
Ian
Hi Ian,
Glad you were able to use a different USB drive. Is the Corsair drive in a different format?
Really pleased to hear it!
Let us know if there’s anything else you need.
