Hi All,
if I type a cue number in the command line and press "go" it will go there.......except for three digit numbers. example: "16"  will work fine, "161" won't.
FLXS 48.
Are you sure? This isn't a feature and doesn't work when I do it.
To jump to a cue, you need to hold down GO, type the Cue Number, and then release GO.
When I try this, it's working for Cue 1, 16, and 161.
I was pretty sure. But I might be wrong of course. I'll try later today! Thanks!!
Thanks Jon, I was wrong indeed. it got a bit late programming....
The method you mentioned works flawless.
  • Like 1
