Ed75 Posted September 11, 2022 Report Share Posted September 11, 2022 Hi All, if I type a cue number in the command line and press "go" it will go there.......except for three digit numbers. example: "16" will work fine, "161" won't. FLXS 48. Quote Freelance Theatre Lighting designer/operator/allround technician/tech production/rental . Netherlands. FLX, FLX S48 2U, Solution, 13" multitouch monitor, 15" portable multitouch monitor, 11.4" lenovo thinkpad touch, network hub with wifi, powered usb hub, keyboard, trackball. 2x Elgato Streamdeck, nodes: showtec 2-3 and Lightshark node-4 2x 19" networkswitch, IOS zeros remote. 22" Iiyama. Link to comment Share on other sites More sharing options...
Jon Hole Posted September 11, 2022 Report Share Posted September 11, 2022 2 hours ago, Ed75 said: if I type a cue number in the command line and press "go" it will go there Are you sure? This isn't a feature and doesn't work when I do it. To jump to a cue, you need to hold down GO, type the Cue Number, and then release GO. When I try this, it's working for Cue 1, 16, and 161. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Ed75 Posted September 12, 2022 Author Report Share Posted September 12, 2022 I was pretty sure. But I might be wrong of course. I'll try later today! Thanks!! Quote Freelance Theatre Lighting designer/operator/allround technician/tech production/rental . Netherlands. FLX, FLX S48 2U, Solution, 13" multitouch monitor, 15" portable multitouch monitor, 11.4" lenovo thinkpad touch, network hub with wifi, powered usb hub, keyboard, trackball. 2x Elgato Streamdeck, nodes: showtec 2-3 and Lightshark node-4 2x 19" networkswitch, IOS zeros remote. 22" Iiyama. Link to comment Share on other sites More sharing options...
Ed75 Posted September 12, 2022 Author Report Share Posted September 12, 2022 Thanks Jon, I was wrong indeed. it got a bit late programming.... The method you mentioned works flawless. 1 Quote Freelance Theatre Lighting designer/operator/allround technician/tech production/rental . Netherlands. FLX, FLX S48 2U, Solution, 13" multitouch monitor, 15" portable multitouch monitor, 11.4" lenovo thinkpad touch, network hub with wifi, powered usb hub, keyboard, trackball. 2x Elgato Streamdeck, nodes: showtec 2-3 and Lightshark node-4 2x 19" networkswitch, IOS zeros remote. 22" Iiyama. Link to comment Share on other sites More sharing options...
