Roland The Roadie Posted August 8, 2022 Report Posted August 8, 2022 The user manual states that the audio input in not activated in the software, this is the original manual and there have been several software updates, is this now activated and if so what does it do? What I would like to do is use an audio feed to activate a light with voice, is this possible? I know the sound to light input is primarily for triggering cues and really needs a bass signal. I would appreciate any suggestions here. R Quote
Edward Z88 Posted August 8, 2022 Report Posted August 8, 2022 Hi @Roland The Roadie Welcome to the Zero 88 Forum. 7 minutes ago, Roland The Roadie said: The user manual states that the audio input in not activated in the software, this is the original manual and there have been several software updates, is this now activated and if so what does it do? The Audio Input and Audio Output jacks on Orb/OrbXF consoles are still not used in ZerOS. There are currently no plans to implement them. 7 minutes ago, Roland The Roadie said: What I would like to do is use an audio feed to activate a light with voice, is this possible? I know the sound to light input is primarily for triggering cues and really needs a bass signal. I would appreciate any suggestions here. The dedicated Sound-to-Light jack can be used to synchronise chases with an audio feed. Although this is designed for use with a bass input, you should still be able to use Sound-to-Light with a mid-range signal input if it is strong enough. If you have any questions, please let us know. Edward Quote Edward Smith Product Specialist Email Support
