SimonH Posted August 7, 2022 Report Posted August 7, 2022 How do I make the button under the fader flash when in channel mode? atm it just selects and deselects the channel. Quote
kgallen Posted August 7, 2022 Report Posted August 7, 2022 You’re pretty experienced so I guess you’ve tried Setup+Button ? Quote
SimonH Posted August 8, 2022 Author Report Posted August 8, 2022 9 hours ago, kgallen said: You’re pretty experienced so I guess you’ve tried Setup+Button ? Yep, just takes me into the fixture set up page unless I’m pressing them in the wrong order. Might have been holding button and pressing setup. 🤦🏻♂️ Quote
Edward Z88 Posted August 8, 2022 Report Posted August 8, 2022 Hi Simon, 16 hours ago, SimonH said: How do I make the button under the fader flash when in channel mode? atm it just selects and deselects the channel. Currently, the MFF buttons in "Channels" function are select buttons. They cannot be configured to be channel flash buttons. The ability to change the channel button function is logged as feature reference number ZOS-7888 on our system. I have raised the priority of this issue following your query. The current thinking is that there will be a global option within the Z window, to change the function of all channel buttons. This behaviour is by no means set in stone. If you have any questions, please let us know. Edward Quote Edward Smith Product Specialist Email Support
