Jouper Posted July 27, 2022 Report Posted July 27, 2022 How can i set the Home Position of a Fixture on a Solution. The manual says Record and then press the home key but the Solution doesn't have a home key. Quote
Edward Z88 Posted July 27, 2022 Report Posted July 27, 2022 Hi @Jouper 33 minutes ago, Jouper said: How can i set the Home Position of a Fixture on a Solution. The manual says Record and then press the home key but the Solution doesn't have a home key. On Solution consoles the HOME key can be found to the left of the second strip of MFKs, below the MFK page buttons. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
Edward Z88 Posted July 27, 2022 Report Posted July 27, 2022 31 minutes ago, Jouper said: found it thank you No problem. If there's anything else we can help with just let us know. Edward Quote Edward Smith Product Specialist Email Support
