Jouper Posted July 27, 2022 Report Share Posted July 27, 2022 How can i set the Home Position of a Fixture on a Solution. The manual says Record and then press the home key but the Solution doesn't have a home key. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted July 27, 2022 Report Share Posted July 27, 2022 Hi @Jouper 33 minutes ago, Jouper said: How can i set the Home Position of a Fixture on a Solution. The manual says Record and then press the home key but the Solution doesn't have a home key. On Solution consoles the HOME key can be found to the left of the second strip of MFKs, below the MFK page buttons. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Jouper Posted July 27, 2022 Author Report Share Posted July 27, 2022 found it thank you Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted July 27, 2022 Report Share Posted July 27, 2022 31 minutes ago, Jouper said: found it thank you No problem. If there's anything else we can help with just let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
