SimonH Posted July 24, 2022 Report Share Posted July 24, 2022 evening all, should I be able to select a single fixture within a cue, adjust its colour and then save that as a pallette and then apply that pallette to all same type of light? Quote Link to comment Share on other sites More sharing options...
kgallen Posted July 25, 2022 Report Share Posted July 25, 2022 If they are all the same type in the same mode (ie identical patch and parameters) then yes I believe that should work… Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted July 25, 2022 Report Share Posted July 25, 2022 Hi Simon, 12 hours ago, SimonH said: should I be able to select a single fixture within a cue, adjust its colour and then save that as a pallette and then apply that pallette to all same type of light? Yes. If you are having difficulty with this, please let us know what you are encountering. If a cue is currently live, it is also possible to save the current colours in the cue to a palette, without adjusting them. To do this, select your fixture(s), then hold CLEAR and tap COLOUR to tag all colour parameters. You can then tap RECORD and tap a palette. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
