P F S Posted August 27, 2002 Report Posted August 27, 2002 You can only make a total off 400 steps in your chases. It might be a good suggestion to increase that amount off steps. Especially for the mambo frog. Quote
K-Nine Posted August 27, 2002 Report Posted August 27, 2002 How many steps would you like ? Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
GLX Posted August 27, 2002 Report Posted August 27, 2002 How many lamp`s have you? if 400 steps is`ent enough. just wondering, cause I get fedup after about 12 steps. :? Quote
P F S Posted August 28, 2002 Author Report Posted August 28, 2002 I've got 8 showtec movingheads, 4 movitec movingheads, 4 futurelight scans, 2 martin movingheads, 2 martin wizzards, 2 martin acrobats, 24 colorchangers, so 400 steps is not to much I think 1000 steps should be enough for now, when I make a chase with several fixtures I like to program them 1 by 1, so step 1 is fixture 1 at position 1, step 2: fixture 2 an position 1, step 3: fixture 3 at position 1, and so on, till I have a nice chase. I know this way of programming takes a lot of time, but it gives a nice show to watch. We've got 2 fat frogs now, and sometimes with a large production we use almost all steps. I'm sure when we buy the Mambo that we will run out of steps. It's the only reason why we're not going to buy it right now. Quote
K-Nine Posted December 10, 2002 Report Posted December 10, 2002 You can only make a total off 400 steps in your chases. It might be a good suggestion to increase that amount off steps. Especially for the mambo frog. This is not strictly true 8O On each of the Frog Series of desks the maximum memory capacity is EQUIVALENT to 400 Full width scenes, where a full width scene is defined as all the available generic and fixture channels used. If all the available fixture channels are not used (as will be the case with most desk setups) the maximum number of memories increases accordingly up to a maximum of 1000 8) Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
