francocampo Posted May 24, 2022 Report Posted May 24, 2022 Good morning If possible disable reset position of moving head when the playback go to 0. Excusme for my English Quote
kgallen Posted May 24, 2022 Report Posted May 24, 2022 Setup+Playback button Release on Lower = no Quote
francocampo Posted May 24, 2022 Author Report Posted May 24, 2022 Hi kgallen thank you very much for your reply. Quote
Edward Z88 Posted May 24, 2022 Report Posted May 24, 2022 For more information, please see the link below... https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/raise-and-lower Thanks @kgallen for the lightning-fast response!! Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted May 24, 2022 Report Posted May 24, 2022 7 hours ago, Edward Z88 said: Thanks @kgallen for the lightning-fast response!! I got lucky as I realised afterwards the question was for Solution and I wasn't sure it had the same buttons or process as the FLX! 🤣 1 Quote
francocampo Posted May 28, 2022 Author Report Posted May 28, 2022 Thanks again Edward and kgallen, actually the problem is that when I switch from one playback to another the moving head lights first go to home position and then go to the programmed cue. so when the current playback goes to 0 the lights remain in the same position and when the other cue is played back the lights do not move. I hope I was as understandable as possible. I apologize for my English and I wish you all good. Thanks again Quote
kgallen Posted May 28, 2022 Report Posted May 28, 2022 Hi Franco Can we go back to the beginning and you list out what you want to do? Quote
francocampo Posted May 30, 2022 Author Report Posted May 30, 2022 On 5/28/2022 at 2:35 PM, kgallen said: Hi Franco Can we go back to the beginning and you list out what you want to do? Hi kgallen thank you for your interest, I would like to make sure that when I change playback the moving heads do not go to home position and then move to the cue in playback. Thanks for all, best regards Quote
Edward Z88 Posted May 30, 2022 Report Posted May 30, 2022 Hi @francocampo 54 minutes ago, francocampo said: I would like to make sure that when I change playback the moving heads do not go to home position and then move to the cue in playback. I believe disabling "Release On Lower" should achieve this behaviour. If you raise a playback for the first time, the fixtures will move from their default values, to the values from the raised playback. If you lower the playback, with release on lower disabled, the fixture's intensity will lower, but their colour, beam and position information will remain. Raising a second playback, will then move the fixture's values from the first playback, to the values of the second playback. If you would like to prepare the fixture's colour, beam and position information, prior to raising the second playback's fader, you could configure the playback's button to be a go button, rather than flash, and tap the button to manually prepare your fixtures. I hope this helps. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
francocampo Posted June 3, 2022 Author Report Posted June 3, 2022 Many many thank's Edward Best regards 1 Quote
