I starterd the ZerOS-7.11.exe on my PC, USB stick was formatted and files were copied to it. Everything seems to be fine in the process. Then I plugged off the FLX S24, entered the USB stick at the back ("behind" the touch panel) and plugged in the board. It started, but there was no new version installed. Attached you will find the system info of the board. What can I do? What is wrong?
