Hi Is ii possible to trigger a macro from a cue stack that has been generated from a fixture file.
I have a fixture that has lamp on and off macros that are auto generated. I want to trigger the lamp off macro from a cue in my cue stack but I am not able to select auto generated macros in the trigger macro screen of the cue I can only trigger macros that I have recorded on the console.
Cheers
Hi @keredyelesob
It is not currently possible to trigger Fixture Macros from cues. It is only possible to trigger User Macros. For more information, please see the link below...
https://zero88.com/manuals/zeros/cues-playbacks/cue-settings/cue-macros
The ability to trigger Fixture Macros from cues is something we would like to implement. This is logged as reference number ZOS-6741 on our system. I have raised the priority of this following your request.
Currently, you could manually record a Lamp Off command into a cue, by setting the relevant Beam parameter to the required level in the cue, rather than using the Fixture Macros.
