SimonH Posted March 1, 2022 Report Share Posted March 1, 2022 Morning all, Just configuring our rig to use RDM and I was just checking that when a show is saved it keeps a record of the RDM ref in relation to the fixture settings? So if I recall a show the fixtures will all be set up correctly? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 1, 2022 Report Share Posted March 1, 2022 Hi Simon, 5 hours ago, SimonH said: Morning all, Just configuring our rig to use RDM and I was just checking that when a show is saved it keeps a record of the RDM ref in relation to the fixture settings? So if I recall a show the fixtures will all be set up correctly? ZerOS will apply your rig configuration to your show file. It will not apply your show file configuration to your rig. Therefore, if you load in a show file, ZerOS will look at the RDM IDs of the fixtures in the show file, to see whether they match fixtures that are currently connected. If there is a match, ZerOS will change the modes and addresses in the show file, to match the fixtures in the rig. In this situation it will not automatically change the addresses and modes of your fixtures. If you have any questions, please let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
SimonH Posted March 2, 2022 Author Report Share Posted March 2, 2022 18 hours ago, Edward Z88 said: Hi Simon, ZerOS will apply your rig configuration to your show file. It will not apply your show file configuration to your rig. Therefore, if you load in a show file, ZerOS will look at the RDM IDs of the fixtures in the show file, to see whether they match fixtures that are currently connected. If there is a match, ZerOS will change the modes and addresses in the show file, to match the fixtures in the rig. In this situation it will not automatically change the addresses and modes of your fixtures. If you have any questions, please let us know. Edward ok thanks for that Edward. Disappointing as it means if a visiting company comes in and changes the mode and address of each fixture I will have to remap everything to get it up and running again. It would be useful to have a similar function to a lot of audio kit in that you can select "update from or to a device" Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 2, 2022 Report Share Posted March 2, 2022 Hi Simon, 11 minutes ago, SimonH said: Disappointing as it means if a visiting company comes in and changes the mode and address of each fixture I will have to remap everything to get it up and running again. For this, you could use the "Revert Rig Back" button. Pressing this button, will revert your fixtures back to the settings they were discovered in. Therefore one you have set your fixtures the required addresses and modes, you could reset your console, and then let your console discover all your fixtures. You can then save this show file, as your base RDM configuration. After the visiting company has come in, you can then reload your base RDM show file, and press Revert Rig Back. For more information, please see the link below... https://zero88.com/manuals/zeros/setup/universes/remote-device-management Hope this helps. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Jon Hole Posted March 2, 2022 Report Share Posted March 2, 2022 Hi Simon, I think the end result will be what you want, but not by the method you expect. When RigSync discovers and patches a fixture, the link between the console and that fixture is the RDM UID, not the DMX address. Therefore, if someone messes up all the DMX addresses and then you load your older showfile in, RigSync will make sure that your showfile works by: Repatching your showfile to match the new addresses Readdressing any fixtures where this isn’t possible (eg overlaps) Also, remember about the “Revert Rig” option. When RigSync discovers your fixtures, it will store the values of those fixtures into the showfile before then making any required changes. So… if your rig is “correct” at the point of RigSync discovery, RigSync will store these settings and patch your fixtures, but not make any changes. If someone messes up all the DMX addresses, you then have the option to load that showfile in and click “Revert Rig” (note – when loading in your showfile, RigSync might automatically make lots of changes to make the rig work, so if you want it back to how it was before, you’ll need to click “Revert Rig” and then reload your showfile) Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Jon Hole Posted March 2, 2022 Report Share Posted March 2, 2022 (@Edward Z88 got there first!) 1 Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
SimonH Posted March 2, 2022 Author Report Share Posted March 2, 2022 Thanks both. So if I do the following: use RDM to patch all my fixtures disconnect from console start a new show file reconnect to console and allow to discover all fixtures as set store this as my base file after visiting company has left reattach my console with base file loaded and press revert rig. Will this re-patch my fixtures to how they were? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 2, 2022 Report Share Posted March 2, 2022 Hi Simon, 1 hour ago, SimonH said: Thanks both. So if I do the following: use RDM to patch all my fixtures disconnect from console start a new show file reconnect to console and allow to discover all fixtures as set store this as my base file after visiting company has left reattach my console with base file loaded and press revert rig. Will this re-patch my fixtures to how they were? That is correct - by "start a new show file", make sure you perform a Reset Desk. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
SimonH Posted March 2, 2022 Author Report Share Posted March 2, 2022 7 minutes ago, Edward Z88 said: Hi Simon, That is correct - by "start a new show file", make sure you perform a Reset Desk. Edward Brilliant thank you. 1 Quote Link to comment Share on other sites More sharing options...
