droiddk Posted February 16, 2022 Report Share Posted February 16, 2022 Hi Some of the good old stuff has to be put into use so I used Phantom Jester to catch up before actually sitting in front of the console. As I found out with Phantom Zeros, Phantom Jester is also very handy learning the basic but I have a simple question: Are some of the functions locked? (cant be changed). For example, in Setup->Record Options I cant change "Brightness" to "Channel". I can change it to "Channel" from "All" but it wont save it. If I go into setup again then Brightness is back on "All". I also had some problems loading new fixture files (including updating to the latest fixture library ver. 41, "default" ver. is 26, Phantom can see the file but wont update) Kind Regards droiddk Quote Link to comment Share on other sites More sharing options...
droiddk Posted February 16, 2022 Author Report Share Posted February 16, 2022 Ahhhh ooops, I just found out that I forgot to un-press "Shift" when doing stuff in Setup ๐ Kind Regards Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted February 16, 2022 Report Share Posted February 16, 2022 Hi @droiddk 1 hour ago, droiddk said: Ahhhh ooops, I just found out that I forgot to un-press "Shift" when doing stuff in Setup ๐ Kind Regards Thanks for the update - as you found, with the SHIFT key held down you wonโt be able to make changes to settings effectively (this is also the case in Phantom ZerOS). Edward 1 Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
