Zulu Posted February 13, 2022 Report Posted February 13, 2022 Hi. Apologies if this question is already addressed somewhere...... I’m working with a FLX S24. Whilst creating a long cue stack for a theatre-style Playback, I am looking to save a cue to a particular, as yet empty, cue, eg cue 45. Is this possible? The lighting state would, by default, save to the next free whole number, which I could copy to the particular cue. But can I do it directly in the “record” action? many thanks, Zulu Quote
droiddk Posted February 13, 2022 Report Posted February 13, 2022 On 2/13/2022 at 7:43 PM, Zulu said: I am looking to save a cue to a particular, as yet empty, cue, eg cue 45. Is this possible? Expand Hi If the cue exists (and maybe is empty) I would simply playback the cue and update it with the look I want, using "Update". If the cue don't exists, and I want it between for example cue 44 and 45 I would simply record a new cue 44.5: Type record and use a keyboard to type in 44.5 and click the cue-stack. If you don't have a keyboard connected you can press "Z/shift" and type 44.5 using the Syntax. If you don't like having a cue 44.5 you can go into advanced playback settings and renumber your cue-stack. Please note that you have to take into consideration tracking-options when you update or insert at new cue into a existing cue-stack. Also, if the look you want exist in a existing cue and you want to record it into a cue in another cue-stack, I think you need to record the cue using Smart Tag or else nothing will be recorded. Maybe this can be useful when using tracking: Kind Regards droiddk 1 Quote
Zulu Posted February 13, 2022 Author Report Posted February 13, 2022 On 2/13/2022 at 8:03 PM, droiddk said: If the cue don't exists, and I want it between for example cue 44 and 45 I would simply record a new cue 44.5. Expand Thanks, droiddk. This describes my requirement, but can’t see where to specify 44.5 during the record action. Quote
droiddk Posted February 13, 2022 Report Posted February 13, 2022 On 2/13/2022 at 8:21 PM, Zulu said: but can’t see where to specify 44.5 during the record action. Expand You simply just type it (right after pressing "Record") using a USB-connected keyboard, or by pressing "Z/Shift" right after pressing "Record" (then you can use the Syntax on the touch-screen to type 44.5). Hope it helps. Kind Regards droiddk 1 Quote
Zulu Posted February 13, 2022 Author Report Posted February 13, 2022 Ah, brilliant. thanks droiddk. I’ll give that a go tomorrow. Quote
