Just double-tap a group so it comes on, and record it on the  fader you wish?? Or am I thinking too simple ?
Hi @pierotec
13 hours ago, pierotec said:
Hi, it is possible to assign groups on the faders?
11 hours ago, pierotec said:
A group should function as a channels page fader.
It is not possible to control a group of fixtures in the programmer (red values in the Output Window) from a fader.
If there is a group of lights you wish to always control together, you could simply patch a single fixture into your console, and then add multiple DMX addresses to it in the Fixture Schedule.
You can record an intensity playback for a group of fixtures as per @Ed75's suggestion above. (On the standard FLX console, you could configure a macro so that raising the playback fader automatically selects the fixtures)
Hope this helps.
Hi Edward,
it would be a feature that could be implemented by taking advantage of the large number of faders available.  It would be very useful in quick editing of theater cue stacks. In the old Frog2 it was possible to do this on UDFs or UDKs.
Thank you
P.
Hi @pierotec
This feature request is logged on our system as reference number ZOS-9027. I have raised the priority of this following your request.
