Fader that Overrides every other active Cue
Jouper
Hi Jouper
Create a state with all the fixtures involved with the strobe effect and the intensity that you need (tag all the others parameters to 0 by highlightning them holding the "clear" button) , then record it into a playback (with all defaults fade button parameters non selected)
you now have a cue in a playback that will override every other cues in others playbacks with the same fixtures .
If i'm telling something wrong, Edward will tell
Hi @Jouper
As @thierry suggests, you can achieve your white strobe effect, if you ensure that you record all the necessary information for your fixtures.
As attributes in playbacks mix Latest Takes Precedence, raising your white strobe effect will be the most recent instruction for your fixtures, and so it will take over from the other active playbacks for the fixtures.
If you are using an effect, rather than a fixture's Strobe parameter, you will need to ensure you set the playback's intensity mixing to Latest Takes Precedence. See the link below for more information...
https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/general
Hope this helps.
Email Support
