Jouper Posted February 6, 2022 Report Posted February 6, 2022 Is it possible to have a fader that overrides every other cue. For example i have my moving lights and everything on my chasers and cues and i want one Fader to set all of them to a white Strobo effect Quote
thierry Posted February 7, 2022 Report Posted February 7, 2022 Hi Jouper Create a state with all the fixtures involved with the strobe effect and the intensity that you need (tag all the others parameters to 0 by highlightning them holding the "clear" button) , then record it into a playback (with all defaults fade button parameters non selected) you now have a cue in a playback that will override every other cues in others playbacks with the same fixtures . If i'm telling something wrong, Edward will tell Quote
Edward Z88 Posted February 7, 2022 Report Posted February 7, 2022 Hi @Jouper As @thierry suggests, you can achieve your white strobe effect, if you ensure that you record all the necessary information for your fixtures. As attributes in playbacks mix Latest Takes Precedence, raising your white strobe effect will be the most recent instruction for your fixtures, and so it will take over from the other active playbacks for the fixtures. If you are using an effect, rather than a fixture's Strobe parameter, you will need to ensure you set the playback's intensity mixing to Latest Takes Precedence. See the link below for more information... https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/general Hope this helps. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Edward Z88 Posted February 7, 2022 Report Posted February 7, 2022 Hi @Jouper 11 minutes ago, Jouper said: Thanks that worked Great, pleased to hear it. 🙂 Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
