Output dmx to sacn and then take another sacn signal and output it on a dmx output
I want to program all my fixtures on my zero solution then output them on sACN and then process this dmx data on something like a pc and send it back to the solution and output it on a dmx output.
Is this possible with just a zero solution?
Hi Jouper,
It is possible to output sACN from Solution. It is not possible to use the Solution as an sACN to DMX gateway, as Solution cannot receive and then convert the sACN data back to DMX.
May I ask what you would like to achieve with the PC processing? It would certainly be possible to send sACN data to a dedicated sACN to DMX gateway, and a PC, simultaneously over a network.
