DALX Posted December 17, 2021 Report Posted December 17, 2021 We have been using the Dell P2418HT touch screen monitor with the FLXS48 but there is no stock available in Australia for at least a few months. Is there an alternative? I have tried my HP Pavilion 23tm and the touch screen does not work, plus an acer that did not work. Quote
Edward Z88 Posted December 17, 2021 Report Posted December 17, 2021 Hi @DALX Any touchscreen that works "plug & play" with Windows 10, and doesn't require any specific drivers, should work with ZerOS. Please see the link below for more information... https://zero88.com/manuals/zeros/desktops-windows/external-display/external-touchscreen Some other users may be able to reply advising what they use. I hope this helps. if you have any questions, please let us know. Edward Quote Edward Smith Product Specialist Email Support
Ed75 Posted December 17, 2021 Report Posted December 17, 2021 I use the following: https://www.beetronics.co.uk/c-touchscreens Very handy and good screens , large angle of view, and work very fine. No drivers required. I use it with a dvi to hdmi cable. no problems. Screens are basically all the same except their diameter, and the material. (plastic or metal) I discovered lately they are also sold without the beetronics brand, on some far-east websites. Exactly the same monitors. saves a few bucks , and may be easier to find for you. 1 Quote Freelance Theatre Lighting designer/operator/allround technician/tech production/rental . Netherlands. FLX, FLX S48 2U, Solution, 13" multitouch monitor, 15" portable multitouch monitor, 11.4" lenovo thinkpad touch, network hub with wifi, powered usb hub, keyboard, trackball. 2x Elgato Streamdeck, nodes: showtec 2-3 and Lightshark node-4 2x 19" networkswitch, IOS zeros remote. 22" Iiyama.
delfine Posted December 19, 2021 Report Posted December 19, 2021 Bonjour puisque vous parlez d'écran, dans une salle nous utilisons la FLX S48 avec cet écran https://www.thomann.de/fr/iiyama_t2453mts_b1.htm Impossible de l'utiliser. le tactile est capricieux (même après calibration) et surtout, et la commande met beaucoup de temps à s'effectuer. Les 2 fois où je me suis confrontée à cet écran, j'ai laissé tomber et j'ai réduit son utilisation à un écran de contrôle sans utiliser le tactile. Pourtant il me semble que cette réference fait partie de celles recommandées. Il a été acheté juste pour cette utilisation et nous sommes très déçu. Y'a-t-il une manipulation que nous avons oublié de faire. Malheureusement cet écran a été acheté pendant la période de confinement et de restriction en France, et nous commençons juste à l'utiliser. il a donc déjà 1 an et demi et n'a pas beaucoup servi. Merci de nous aiguiller. D Quote
Edward Z88 Posted January 5, 2022 Report Posted January 5, 2022 Salut @delfine J'ai jeté un coup d'œil au site Web d'Iiyama et rien n'indique que ce moniteur ne serait pas compatible avec ZerOS... https://iiyama.com/gl_en/products/prolite-t2453mts-b1/ Selon les informations du pilote, il est "plug & play" avec Windows 10 et devrait donc fonctionner avec ZerOS. Si vous connectez l'écran tactile à un PC Windows, l'écran tactile fonctionne-t-il correctement ? Pendant l'étalonnage, arrivez-vous à dessiner correctement sur l'écran ? Si vous avez des questions, s'il vous plaît laissez-nous savoir. Hi @delfine I have taken a look at the Iiyama website, and there's nothing to suggest that this monitor wouldn't be compatible with ZerOS... https://iiyama.com/gl_en/products/prolite-t2453mts-b1/ According to the driver information, it is "plug & play" with Windows 10, and so should work with ZerOS. If you connect the touchscreen to a Windows PC, does the touchscreen function correctly? During calibration, are you able to draw on the screen correctly? If you have any questions, please let us know. Edward Quote Edward Smith Product Specialist Email Support
delfine Posted January 5, 2022 Report Posted January 5, 2022 Bonjour Edward, je n’ai pas essayer avec un pc Windows car j’ai un mac. Et cet écran est dans une salle de spectacle dans laquelle je vais peux vu le contexte. Oui, nous le calibrons, pouvons dessiner, mais il réagit très lentement aux commandes tactiles. A deux reprises je me suis retrouvée à travailler avec, et c’était impossible de travailler dans ces conditions. pour ma part, à titre perso, j’utilise une tablette en second écran, c’est plus réceptif mais moins confortable. Je suis vraiment embêtée avec cet écran. Quelqu’un d’autre a des retours sur les écrans tactiles. merci Quote
kgallen Posted January 5, 2022 Report Posted January 5, 2022 Hi Delfine, I have the "original" Iiyama touch screen which is "resistive". It is also very slow on my FLX. Your screen is "optical" touch. It sounds like it is also very slow. A screen like an iPad is "capacitive". I think these are the fastest. Maybe you should consider a capacitive touch screen? J'ai l'écran tactile "d'origine" Iiyama qui est "résistif". Il est également très lent sur mon FLX. Votre écran est tactile "optique". On dirait que c'est aussi très lent. Un écran comme un iPad est « capacitif ». Je pense que ce sont les plus rapides. Peut-être devriez-vous envisager un écran tactile capacitif ? Regards, Kevin Quote
delfine Posted January 5, 2022 Report Posted January 5, 2022 Sauf qu’il a été acheté depuis plus de 1 an, pendant le confinement en France. nous avons juste suivi les recommandations données Du coup, je me demandais s’il y avait pas une autre raison. Là le côté tactile ne sert à rien. kgallen ? Tu t’en sers en tactile malgré tout de ton écran ? Quote
kgallen Posted January 5, 2022 Report Posted January 5, 2022 14 minutes ago, delfine said: kgallen ? Tu t’en sers en tactile malgré tout de ton écran ? I would like to, but the touch is too slow for anything except basic operations and it is not multi-touch. However it is 17" (43cm) screen which suits my work position. The capacitive screens available are much larger (22", 56cm) and such a screen is too large to fit my workspace. So for most touch operations I rely on the FLX internal touch screen. J'aimerais bien, mais le toucher est trop lent pour autre chose que les opérations de base et ce n'est pas multi-touch. Cependant c'est un écran de 17" (43cm) qui convient à ma position de travail. Les écrans capacitifs disponibles sont beaucoup plus grands (22", 56cm) et un tel écran est trop grand pour s'adapter à mon espace de travail. Donc, pour la plupart des opérations tactiles, je m'appuie sur l'écran tactile interne FLX. At the time of purchase I too did not understand the different screen types. Au moment de l'achat, je ne comprenais pas non plus les différents types d'écran. Quote
jmd Posted May 13 Report Posted May 13 Bonjour, J'ai un écran tactile ilyama prolite t2452MSC et je n'arrive pas à le configurer. J'ai pourtant suivi la documentation mais l'écran tactile ne répond pas. Vous pouvez m'aider ce serait génial merci 🙏 Quote
Edward Z88 Posted May 13 Report Posted May 13 Salut @jmd Tout d’abord, assurez-vous que votre FLX S48 exécute un logiciel à jour. Si vous n'êtes pas sûr de la version utilisée par votre console, veuillez me le faire savoir. Ensuite, veuillez calibrer le moniteur externe. Veuillez consulter le lien ci-dessous pour plus d'informations, notamment sur la marche à suivre si l'écran tactile ne répond pas... https://www.zero88.com/manuals/zeros/setup/settings/displays#calibration Si l'écran tactile ne répond toujours pas, veuillez fournir un lien vers la page Web de votre moniteur sur le site Web d'Iiyama, et nous pourrons enquêter plus en détail. Hi @jmd Firstly, please ensure your FLX S48 is running up to date software. If you're not sure what version your console is running, please let me know. Then, please calibrate the external monitor. Please see the link below for more information, including what to do if the touchscreen does not respond... https://www.zero88.com/manuals/zeros/setup/settings/displays#calibration If the touchscreen is still not responding, please provide a link to your monitor's webpage on the Iiyama website, and we can investigate further. Quote Edward Smith Product Specialist Email Support
jmd Posted May 13 Report Posted May 13 Bonjour, j'utilise la version 714.2 Mais la configuration tactile ne fonctionne pas, j'ai bien la croix sur mon écran tactile ,mais impossible de le configurer. J'ai pourtant bien lu la documentation et cet écran est pourtant compatible avec la flx s48 Quote
jmd Posted May 13 Report Posted May 13 Problème résolu, simplement un câble USB défectueux. Merci 1 Quote
