van den abbeele Eric Posted November 27, 2021 Report Share Posted November 27, 2021 Hello, Yesterday I Use for the first time UDK possibility... this is Service (security) light. Having two fixture light on (Cannal 37 and 38) and after need it light Off (Latch option) So when the UDK is "on" and I want to recording other light in a CUE, This two light 37 & 38 are recording with... So I would like to recording all the light without this two projector... How can I Use UDK for this ? thank Quote Link to comment Share on other sites More sharing options...
martin-144 Posted November 27, 2021 Report Share Posted November 27, 2021 Hi Eric, I think at the moment it is not possible to do what you want to do in an easy way. That's why I voted for "Exclusive Playbacks (a playback not affected by GM, RemDim, Inhibits, other Playbacks, and not recorded into cues)" in thishttps://zero88.com/forum/topic/9266-what-would-you-like-to-see-in-zeros/ survey. Cheers, Martin Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 27, 2021 Report Share Posted November 27, 2021 Hi @van den abbeele Eric As @martin-144 mentions, there is currently no dedicated way of configuring a UDK to not be included when recording a cue. However, if you record cues with SmartTag disabled, only values that you manually adjust will be recorded, and values coming from cues and UDKs will be ignored. The other potential option, if you could Park channels 37 and 38. See the link below for more information… https://zero88.com/manuals/zeros/user-definable-keys/advanced-udks/parking Hope this helps, Edward Quote Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted November 28, 2021 Author Report Share Posted November 28, 2021 Thank Edward & Martin, This will be good to have possibility to command some independent Light (or other operation) with the possibility to affect OR NOT GM & selective playback. To have a option for have action or not on FLX selective part ... Have a nice day Quote Link to comment Share on other sites More sharing options...
