Im setting up for a show and have been presented with a starcloth !
I have the DMX channel list but the cloth is not on the fixture library !
I have the fixture tools but am not sure how to setup a starcloth to work with the new ZERoS - Any help gratefully recieved.
Ch1 - Dimmer
Ch2 - LED 1
Ch3 - LED 2
Ch4 - LED 3
Ch5 - LED 4
Ch6 - Strobe
Ch 7 - Programs / Presets
Ch 8 - Program Speed
You can use the "old" fixture tools in the same way you did before - it's just they don't support creating the new format for Multicell fixtures.
It looks to me that the channel list above is fairly "old skool" - no Multicell fixture there, so just use the Fixture Tools as you did before.
Do you need this real quick? If so I could probably knock this up now as I'm in front of the computer (currently watching Edward's ZerOS 7.10 videos...).
... attached.
aaron_starcloth.ift
Forgot to say - you have an overall dimmer (intensity) then you’ll find the other controls under Beam (or Shape maybe!).
Ping back here if you want changes - although it sounds like you’ve used the Fixture Editor before so if you have a PC close by maybe you can make mods yourself.
Kevin
