how this new Update 7.10 is going ? Well ?
van den abbeele Eric
Hello
All is in the title, what do you think about this new update  ?
Stable version ?
Some problems ?
Thank for you return
Eric
1 FLX + 1 wing  "7.14" + 1  FLX "7.13" & 3 Wings  / 2 Touchscreen  // Jester 24/48
2 Swisson XND-4R5 ENode  // Stairville : 5 Wash MZH 19X15w  - 31 Retro Flat Par 18X 12w RGBW
LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W   // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w
olé
No return about 7.10 update ?
Not yet. Have been doing some testing, nothing funny till now.
And I had an upcoming  theatre job for a month......start date would have been last monday, sunday evening everything cancelled......
Yesterday evening the rest of the usual theatre work cancelled for at least another three weeks. All pandemic panic. So no 'live' testing coming weeks........
Which leaves me enough time to test now, but not 'live' . I do not posess any multi-cell fixtures, so can't comment on that.
Yesterday I had my  last job for the coming weeks.....took the FLX S48,  had to set it up in half an hour,  and it worked fine. Simple job though. only 48 dimmers.
I busk most of my shows so I have a pretty extensive default setup meaning I have something repeatable covering all the features I use but I was still on 7.9.5 or 6. I also have Captur set up for the matching rig.
So I upgraded my FLX, straight to 7.10 on Monday. Loaded up my default show, had a bit of trouble re-establishing the link to Captur but otherwise no issues.
Changed all the "red" fixtures to the new library. Had to hunt a bit for one fixture type, ended up with a generic IRGBAWUvSt but otherwise had a match for everything.
Tested again on Captur, all good.
First show was on Thursday, no desk issues (the band were a different story 😀). It was a simple show though, not a serious work out.
Of course there's a few differences, been so used to where all the beam parameters were it's fun finding them among the beam/shape pages but I'll get used to it in time. Slightly annoyed that one thing didn't change - if I'm setting beam parameters (usually zoom & focus) and I select the next fixture the parameters change to the last page and I have to change it back. This happened on the old version but I hoped it would go away 😞.
No "proper" workout until 8th December (all conferences and touring lights until then) but I'll report back if I find anything.
Hi David & Ed,
Thanks for the feedback.
Sorry to hear this.
Glad to hear the update to 7.10 was pretty smooth for you. You’ll get used to the Beamshape split in time! As a general rule, any parameter that “cuts into” the beam of light is a Shape parameter. Lenses and other functions are Beam parameters.
This issue was logged as reference number ZOS-8721, and as per the release notes, should be fixed in ZerOS 7.10. Selecting a fixture, should now take you to the first parameter page for an attribute. If this isn’t the case, let me know which fixtures you are having difficulty with, and I’ll take a look.
I don't think that was the case. Maybe it depends on how you select (touch screen, keypad or next/previous). I'm in theatre for a conference Monday so I should be able to report back then. Good to know it is on the radar though and possibly fixed although I'd have preferred it to just stay where it was. Thanks for the feedback.
  • 2 weeks later...
Hello ...
Other Bug or problems on FLX with 7.10 ?
Have a nice day
Hi @van den abbeele Eric
These are the issues we are aware of in ZerOS 7.10 software, that have been discovered since launch:
  • Viewing the Fixture Levels window on legacy consoles can cause a crash
  • Encoders can sometimes not work correctly on linear multicell fixtures if their cells have been reversed
  • Channel Auto-Select on Fader Movement behaviour in Fixture Schedule is incorrect
  • Fixture parameter values are not included in CSV exports
I hope this is helpful.
Thank Edward.
A new update is it coming soon for user ?
Take care
Eric
That's a good thing ! Wish that you will do this in the better time !
