Gabriel070 Posted November 5, 2021 Report Posted November 5, 2021 hi is there a 3D view program i could use for my jester ml 24? thanks Quote
iank99 Posted November 5, 2021 Report Posted November 5, 2021 There isn't a program in the Zero88 software stable but any "visualiser" program would do the job I suspect, they take DMX from the desk and display a representation of the scene's you're building. However.... The visualisers aren't cheap, they don't work "out of the box" - they do need a lot of setting up i.e you need to declare the fixtures/luminaires you're using, where they're located in the performance (height, angle of throw, field angle of the fixture) and setup attribute definitions and DMX addresses. I suspect given that you're asking about an ML24 yours will be a relatively small rig so you might not get the value out of the visualiser that a full size concert designer would? If you're regularly going to light in spaces that you don't have access to before your show arrives - there might be some benefit to a visualiser but I personally have doubts about that. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
