Gabriel070 Posted November 5, 2021 Report Share Posted November 5, 2021 hi is there a 3D view program i could use for my jester ml 24? thanks Quote Link to comment Share on other sites More sharing options...
iank99 Posted November 5, 2021 Report Share Posted November 5, 2021 There isn't a program in the Zero88 software stable but any "visualiser" program would do the job I suspect, they take DMX from the desk and display a representation of the scene's you're building. However.... The visualisers aren't cheap, they don't work "out of the box" - they do need a lot of setting up i.e you need to declare the fixtures/luminaires you're using, where they're located in the performance (height, angle of throw, field angle of the fixture) and setup attribute definitions and DMX addresses. I suspect given that you're asking about an ML24 yours will be a relatively small rig so you might not get the value out of the visualiser that a full size concert designer would? If you're regularly going to light in spaces that you don't have access to before your show arrives - there might be some benefit to a visualiser but I personally have doubts about that. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
