Hi.
First post from me is a request for suggestions. i have got several profiles in my rig at the mo and am looking to make a "forest in the daytime" sort of effect (like how Chessington does it on the Gruffalo). I currently have them running as a chase on a MFF, but was wondering if there was a better, or easier way of getting the effect I have been looking for.
Hope this explains the idea. if you don't understand, i don't blame you! pretty awful at explaining stuff at the best of times.
Thanks all!
Adam
Hi Adam,
Welcome to the Zero 88 Forum.
Rather than using a chase, have you tried using some of the intensity effects available? If not, you may find one of these gives the result you're after.
To watch a webinar on Chases and Effects on ZerOS consoles, see below...
Hope this helps,
Thank Edward. found some good ideas, but is it possible to offset the fixtures entirely (so no 2 fades are the same, if that makes sense?)?
The reason I made the chase was because of the ransom order, which, as you know, mixes the order of the 15 or so cues i programmed in. set it with a very low BPM (I think I did it at 11 BPM) to adjust the light output overall.
God knows if this explains anything, or if i am just drabbling. Forgive me if this makes absolutely no sense whatsoever!
Hi Adam,
To provide a custom offset across your fixtures, you will be able to hold Z/Shift, and dial the offset encoder. Your fixtures will start to offset. For more information, please see the link below...
https://zero88.com/manuals/zeros/effects/effect-parameters#offset
Each time you apply a random offset to an effect, the console will come up with a random order. With chases, random will automatically choose a random next cue each time.
If you have any questions, please let me know.
