Gul Posted November 2, 2021 Report Posted November 2, 2021 Hi, i'm facing an issue i dont understand: using FLXS48 i'm recording several cues for a theater show (with tungsten and led fixtures: MARTIN RUSH2 and ETC LUSTR+), on general playback, using fade times. the trouble is when the LUSTR fixtures comes with different colors between 2 cues, i cant get the right color fade time, it happens "cut" : the new color comes at the very beginning of the transfer. it only comes with color fade time if intensity changes... that doesnt happens with the RUSH PAR! I would say, some parameters in LUSTR are responsible of that, but i cant figure out what it is. Or, did i miss something in the record parameters of my cues?? i hope i am clear. thanks for your help! Quote
kgallen Posted November 2, 2021 Report Posted November 2, 2021 Have you got the colour fade time at 0s (snap) on those cues that aren't intensity fading? Attach your showfile here. Quote
Edward Z88 Posted November 3, 2021 Report Posted November 3, 2021 Hi @Gul Welcome to the Zero 88 Forum. 11 hours ago, Gul said: the trouble is when the LUSTR fixtures comes with different colors between 2 cues, i cant get the right color fade time, it happens "cut" : the new color comes at the very beginning of the transfer. Can you confirm that "Fader Controls Colour" is disabled for this playback? To ensure it is, hold SETUP and tap your playback's button. From the settings ensure the "Colour" button has a blue stripe under "Fader Controls..." and click OK. If this option is enabled, fade times will not be used for colour transitions. This would not explain why your Martin fixtures were fading correctly, but worth checking this setting anyway. 11 hours ago, Gul said: I would say, some parameters in LUSTR are responsible of that, but i cant figure out what it is. Or, did i miss something in the record parameters of my cues?? 10 hours ago, kgallen said: Attach your showfile here. As @kgallen says, please attach a copy of your show file, and describe which fixtures and cues you are seeing the issue with. We'll then be able to investigate. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted November 3, 2021 Report Posted November 3, 2021 40 minutes ago, Edward Z88 said: As @kgallen says, please attach a copy of your show file, and describe which fixtures and cues you are seeing the issue with. We'll then be able to investigate. I hoped it might have been posted last night so you had something to look at this morning... 🙃 Quote
Gul Posted November 4, 2021 Author Report Posted November 4, 2021 Well, thanks a lot guys! @Edward Z88, you were totally right, i didn't disabled "fader color control" in master playback ! i did in general setup, but had no effect. what i don't understand is why is this option "ignore" by default? more useful when disabled, isn't it? By the way thanks for fast answering, and perfect efficiency! I'm beginning with FLX 48S and even if there is still some dark point, i start appreciating it! thanks again! see ya🤠 Quote
Edward Z88 Posted November 5, 2021 Report Posted November 5, 2021 Hi @Gul 20 hours ago, Gul said: Well, thanks a lot guys! @Edward Z88, you were totally right, i didn't disabled "fader color control" in master playback ! Glad that solved the issue. 20 hours ago, Gul said: what i don't understand is why is this option "ignore" by default? more useful when disabled, isn't it? Fader Controls Colour should be disabled by default. For more information, please see the link below... https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/general#fadercontrols Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
