Hi all.
Recently bought a zero 88 frog 2 with a error message as reads: "Non-volatile RAM Retention test failed. The internal battery may need replacing."
I assume this is the cr2032 battery inside?
I'm not that confident with how to replace this battery so some help will be majorly appreciated.
Cheers,
- Jake
Hopefully Edward/Jon/Keith will give you some other details. I didn't find anything about the battery in the user manual. Not sure if there are 1 or more.
Looks like 2 screws each side? Lift the lid slowly as I bet there are ribbon cables from the top panel to main PCB mounted in the base.
59 minutes ago, KWR88 said:
PM on the address below will let you have some more info on how to access the desk correctly
I have messaged you privately to understand more, thank you!
