Hi.
Been using FLXS48 for a couple of years and have built up quite a lot of shows.
Certain parts of a cue stack of a show I would like to capture and merge in to another show. I appreciate that renumbering may be required but being able to 'tack it' on the end of a new cue stack would be perfect.
Hi @martin o
Welcome to the Zero 88 Forum.
Upon loading a show file, you will completely wipe the current show file, and replace it with the loaded show. There is therefore no way of importing certain cues from one show into the current show file.
Cues within a show file can be transferred to other playbacks in the same show file if required.
Product Specialist
Email Support
Thanks Edward. I couldn't think there was but having watched many of the You Tube tutorials and discovering the power of the FLXS, I thought I may have missed something. Again, excellent tutorials and support. Many thanks.
Hi Martin,
No problem. Thanks very much for the feedback.
If there's anything else you need just let us know.
Product Specialist
Email Support
You could play back the old cue stack in PhantomZerOS so you can see what is in the cue you want to copy and record it into your current show. Not sure where you would find earlier versions of PhantomZerOS to load in shows from earlier version show files.
