NO COLOR MIXING
quisqui
Hi there,
following this method: select group, add color, record onto a playback and so on with a different color on a differnt playback, it is imposible to mix colors as the fader that is activated the latest takes preference and complitely cancel the other one.
I´ve tried changing every possible parameter in settings (htp/Ltp) and one way or another the color mixing its imposible .
Any help please?
Ta
Hi @quisqui
Welcome to the Zero 88 Forum.
By default, colour will mix between playbacks using Latest Takes Precedence. This means upon raising a playback, your lights will go to the colour recorded on the playback. They will not mix between the playback you have raised, and any existing playbacks that may be active.
To achieve colour mixing on playbacks, such as creating yourself a Red, Green and Blue playback, see the link below...
https://zero88.com/manuals/zeros/cues-playbacks/playing-back-cues/rgb-colour-mixing-on-playbacks
14 minutes ago, kgallen said:
The previous thread in this section of the forum is the same question.
Please also have a read of the thread @kgallen linked to, which includes other tips and advice.
I hope this helps, if you have any questions, please let us know.
Product Specialist
Email Support
