« Tagged »
delfine
I’m sorry but i’m french and  I don’t understand exactly what’s mean « tagged » for parameter or fixture.
so, I always use « selected » fixture, but it’s so long, for exemple :
I want my fixture 1 in red, and my fixture 2 in blue and record the all in a playback :
i select fixture one, i adjust my intensity and my color
i do thé same for the fixture 2, and so my fixture 1 is unselected, and my fixture 2 selected.
So i select the fixture 1 and the fixture 2 and
long record, and i chose selected fixture, and tape the playback button.
my exemple is for only 2 fixture, and it’s ont really easy for many fixtures.
Is « smart tagged » or « tagged parameter » can help me ?
the translation in french isn’t clear about that… I search many Times.
More, if i choose an option record, does it stay live that for all the futur record, for all the playback.
i l’ost many minutes with that.
thanks a lot for help me to see clear with that and sorry for my english.
delphine
Hi Delphine,
A "tagged" parameter, will get recorded into a cue. An "untagged" parameter will not.
If you have SmartTag enabled in the Record Options, you will not need to worry about tagging, as the console will automatically tag and untag the required parameters at the point of recording a cue.
With SmartTag disabled, you must ensure that the parameters you wish to record are tagged. Parameters you adjust will be tagged automatically, but you can also manually tag and untag parameters.
The relevant section of the English online manual can be found here...
https://zero88.com/manuals/zeros/controlling-fixtures/tagging
The "Selected Fixtures" option in the Record Options, allows you to record the tagged parameters of only the selected fixtures, rather than the tagged parameters of all fixtures. The relevant section of the English online manual can be found here...
https://zero88.com/manuals/zeros/cues-playbacks/record-options/record-filters
The SmartTag and Tracking options, will not automatically change. Therefore once you have chosen SmartTag/Tracking options, these will stay set until you change them.
The Snapshot and Record Filters options will revert to default after each record. The relevant section of the English online manual can be found here...
I hope this helps, if you have any questions let us know.
Product Specialist
Email Support
Citation
Un paramètre "marqué" sera enregistré dans une file d'attente.  Un paramètre "non balisé" ne le sera pas.
J'ai bien compris, mais "Tagged" veut dire quoi ? Tout ce qui est rouge ?
Citation
L'option « appareils sélectionnés » dans les options d'enregistrement, vous permet d'enregistrer les paramètres étiquetés des appareils sélectionnés, plutôt que les paramètres étiquetés de tous les appareils.  La section correspondante du manuel en ligne en anglais se trouve ici...
ça veut dire que dans mon exemple, je suis ben obligé de re selectionné tous mes appareils pour les enregister dans ma cue ?
Et cette otption n'est valable que pour une suite de cues, des séquences, n'est ce pas ?
Vous me écrire vers le manuel en anglais dont le terme "tagged" n'est pas clair pour moi.
Citation
Si vous avez activé SmartTag dans les options d'enregistrement, vous n'aurez pas à vous soucier du marquage, car la console marquera et supprimera automatiquement les paramètres requis au moment de l'enregistrement d'une mémoire.
Je n'arrive vraiment pas à comprendre cette notion.
Si j'ai mes faces d'allumées, mais que je suis en train de régler mes couleurs au sol, je suis obligés de selectionner que mes projecteurs au sol ? non ? Que fait "smart tag" ?<
Désolée ces notions ne son tpas comprend, et j'ai l'impression de perdre mon temps lors de mes programmations.
Les paramètres d'intensité "Tagged", sont indiqués en rouge dans la fenêtre de sortie. Les paramètres LTP balisés (couleur, faisceau, forme, position) ont un fond bleu clair sur l'écran de l'encodeur, plutôt qu'un fond sombre.
"Tagged" intensity parameters, are indicated in red in the Output Window. Tagged LTP parameters (Colour, Beam, Shape, Position), have a light blue background on the encoder display, rather than a dark background.
Non - vous n'avez pas besoin de sélectionner les appareils pour les inclure dans les cues. Ceci n'est requis que si vous avez choisi l'option "Sélectionnées d'appareils" dans la fenêtre Options d'enregistrement.
No - you do not have to select fixtures to include them in cues. This is only required if you have chosen the "Selected Fixtures" option in the Record Options window.
Je recommanderais de programmer avec SmartTag activé. L'option SmartTag est disponible dans la fenêtre Options d'enregistrement. Si le bouton a une bande rouge, cela signifie qu'il est activé. Lorsque SmartTag est activé, vous n'avez pas besoin de penser au marquage, car la console le fera pour vous, pour s'assurer que les paramètres corrects sont enregistrés dans la mémoire.
Si vous avez des questions, laissez-nous savoir.
I would recommend programming with SmartTag enabled. The SmartTag option is available in the Record Options window. If the button has a red stripe, this means it is enabled. When SmartTag is enabled, you do not need to think about tagging, as the console will do it for you, to ensure the correct parameters are recorded into the cue.
Product Specialist
Email Support
Quote
Je recommanderais de programmer avec SmartTag activé. L'option SmartTag est disponible dans la fenêtre Options d'enregistrement. Si le bouton à une bande rouge, cela signifie qu'il est activé. Lorsque SmartTag est activé, vous n'avez pas besoin de penser au marquage, car la console le fera pour vous, pour s'assurer que les paramètres corrects sont enregistrés dans la mémoire.
Dans mon exemple, je vais donc enregistrer la face, ce que je ne souhaite pas.
Quote
Non - vous n'avez pas besoin de sélectionner les appareils pour inclure dans les repères. Ceci n'est requis que si vous avez choisi l'option "Sélectionnées d'appareils" dans la fenêtre Options d'enregistrement.
Si je laisse "fixtures tagged", les fixtures dont les intensités sont rouges et attributs bleus, seront enregistrés. ça je comprends.
