ethan1997may Posted August 3, 2021 Report Posted August 3, 2021 How do I change the defaults on a generic LED fixture? I have tried going about the route of change the value and recording to the home button however it always reverts back to its original status with R G B at full. Thanks for any help. Quote
ethan1997may Posted August 3, 2021 Author Report Posted August 3, 2021 I've also found another problem this morning since I updated to the latest software. For some reason I am no longer able to record macros, whenever I go to record one and hit the key it comes up with "there are no fixture selected" Any help would be appreciated Quote
Edward Z88 Posted August 3, 2021 Report Posted August 3, 2021 Hi Ethan, On 8/3/2021 at 9:05 AM, ethan1997may said: How do I change the defaults on a generic LED fixture? I have tried going about the route of change the value and recording to the home button however it always reverts back to its original status with R G B at full. Expand To be able to customise fixture Defaults, you will need to ensure that your console has tracking options enabled, and is not in global Cue Only mode. For more information on Global Tracking Options, see the link below... https://zero88.com/manuals/zeros/cues-playbacks/record-options/tracking#GlobalOptions You will also need to ensure the SmartTag button in the Record Options is disabled. For more information see the link below... https://zero88.com/manuals/zeros/cues-playbacks/record-options/snapshot-smarttag#smarttag I hope this helps, if you have any questions let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Edward Z88 Posted August 3, 2021 Report Posted August 3, 2021 Hi Ethan, On 8/3/2021 at 9:33 AM, ethan1997may said: For some reason I am no longer able to record macros, whenever I go to record one and hit the key it comes up with "there are no fixture selected" Expand We are aware of an issue on Solution consoles, where you cannot choose an MFK when recording a Macro. You can however record a Macro directly into the Macros window on the external monitor. To open the Macros window, hold SHIFT and tap MACROS. You can then tap RECORD, and click an empty Macro tile in the Macros window. After typing your button sequence, you can then tap the MACROS button to finish recording. I hope this helps, if you have any questions let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
