DMX in controls fader
Jouper
Is it possible to get dmx inputs from another controller like a dmx software and send them to the dmx controll?
So as an example i have a dmx controll software and i am controlling my moving head with a joystick and sending this dmx outputs is it possible to pass it trough to my moving head but when i want to controll the moving head from the zero its also possible?
Hi Jouper,
Solution consoles do feature a DMX input. DMX input channels can either be assigned to remotely control the intensities of patched fixtures, or to control the levels of programmed playbacks. The DMX input cannot be used as a merge between the console outputs and the incoming data.
Configuring the DMX input to control fixture intensities, is done using the DMX Input column of the Fixture Schedule. Configuring the DMX input to control playbacks is done by tapping SETUP -> Triggers, and adding playbacks under the DMX In option.
I hope this helps, if you have any questions let me know.
