Parameter recording, ... or maybe 'unwanted' parameter recording!
phosphene
I am fighting the FLX-S 48's tenedency to record all the parameters.
Personally I am trying to put position, beam, colour and intensity in seperate playbacks to allow the sort of manual busking I used to enjoy with desks like Sirius 250 (OK I'm old) but am defeated.
Yes I have the idea of press and hold record to give some options! Please can we have a clear indication of whether a red / green / or blue stripe means a parameter will or won't be recorded? Repeated attempts touching to change the indicator stripe colour don't seem result in consistant recordings.  Is there a trick I'm missing here... or is it just not possible to make the playbacks be the equivalents of the old style banks of selectable position/beam/colour buttons and also have some playbacks as channel intensity only states to do the sort of thing I'm describing?
Hi Phosphene,
See the link below for information on the Record Filters and the colour coding...
https://zero88.com/manuals/zeros/cues-playbacks/record-options/record-filters
Using the filters, along with tagging and untagging parameters, you will be able to fully decide what parameters do and don't get recorded into cues. For information on tagging, see the link below...
https://zero88.com/manuals/zeros/controlling-fixtures/tagging
Hope this helps,
Product Specialist
Email Support
