DMX Splitter Compatibility
RJW
Connecting our FLX S48 console to an Event Lighting Split124 4-way DMX splitter results in the green signal LED's of the splitter to rapidly flicker. The flickering is not present when connected to either our LSC Maxim XL or Eurolite LC2412 consoles. Is the flicking an issue of compatibility? Is it likely to cause of signal disruption? Is there a risk of console or splitter damage?
The manual is very minimal,
Split124_Manual_aa6c2998-31db-488c-877c-
but I would expect the DMX light on the front of the unit to flicker very rapidly (almost imperceptibly).
If it’s more noticeable with the FLX then it’s possible your other (budget) consoles don’t send a DMX break time of a length (possibly out of spec for the minimum) that causes the LED to blank.
These cheap splitter units aren’t sophisticated, the LED is just driven from the output of the input side RS485 receiver chip. They aren’t decoding the DMX at all. My Showtec splitters are the same.
I’m assuming your connected lights are receiving the DMX ok?
Note this splitter will not support RDM but I suspect it’s unlikely you’re using this anyway.
  • 10 months later...
I use several types of DMX Splitter, 2 Chanels 4 channels, 6 channels, With or Without RDM, From different brands and having 3 & 5 XLR pin...
I use also DMX Merger for connect 2 lighting consoles. (FLX and a 24/48 jester)
All is working good with FLX and ZerOS...
  • Like 1
1 FLX + 1 wing  "7.14" + 1  FLX "7.13" & 3 Wings  / 2 Touchscreen  // Jester 24/48
2 Swisson XND-4R5 ENode  // Stairville : 5 Wash MZH 19X15w  - 31 Retro Flat Par 18X 12w RGBW
LedStage : 5 PARWASH 19 X 15w // 10 Spot 200w // 19 Wash Par 12 X 18W   // 2 BOWLDER 12X40w WASH // 11 PARZOOM 19 X 15w
