Roan Posted April 30, 2021 Report Posted April 30, 2021 Hi, I run QLab on a MacBook > connect with USB-Midi in/out > FLX. I can trigger a cue in FLX Playback with QLab but not the otherway around; from FLX to QLab. Does anyone knows? Quote
kgallen Posted April 30, 2021 Report Posted April 30, 2021 I don’t believe this is possible (I have a similar application requirement too). I believe the MIDI output is ‘thru’ not ‘out’ and I’m not aware of any commands or macros that can trigger the FLX to output MIDI control messages to other equipment. This is a shame - the only output available on FLX is DMX (XLR or via ArtNet/sACN), there are no ‘aux’ type outputs. Quote
Edward Z88 Posted April 30, 2021 Report Posted April 30, 2021 Hi Roan, As Kevin says, FLX can receive MIDI, but not output MIDI triggers. The MIDI output is for connecting other devices on the MIDI daisy chain so they can all receive the same signal. For more information on MIDI see the link below… https://zero88.com/manuals/zeros/setup/triggers Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Roan Posted April 30, 2021 Author Report Posted April 30, 2021 On 4/30/2021 at 11:25 AM, Edward- Z88 said: Hi Roan, As Kevin says, FLX can receive MIDI, but not output MIDI triggers. The MIDI output is for connecting other devices on the MIDI daisy chain so they can all receive the same signal. For more information on MIDI see the link below… https://zero88.com/manuals/zeros/setup/triggers Hope this helps, Edward Expand It helps, thanks for the sespons. But it is disappointing. Has there never been a need to be able to do this? And then preferably with OSC, so that you do not need a midi converter, only with a Cat cable. Quote
Edward Z88 Posted April 30, 2021 Report Posted April 30, 2021 On 4/30/2021 at 4:16 PM, Roan said: And then preferably with OSC, so that you do not need a midi converter, only with a Cat cable. Expand OSC triggers are on the list, as an addition to the Triggers tab of Setup. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
