HI
I have just purchased 6 Chauvet Colorado Zooms. My issue is when ever I push up a fader with memory on it the fixture snaps on at about 20percent and then fades up to full eg Red 100% Blue100% Green 100% White100% and then falls back to its programmed colour say Straw. When I pull the fader down the last 20% the fixture snaps off. You told me how to remedy this on your course but am afraid I've forgotten.
Pete
Hi Pete,
Hope you’re well.
This sounds like the trigger level of the playback has been changed to 20%. To access this option, open the playback’s settings by holding SETUP and tapping the playback’s button. Then choose the Raise and Lower tab from the top. You will then be able to adjust the Trigger/Release level. The default is 5%, however if you want to access the full range of dimming you could adjust this to 1%. For more information on Raise and Lower, see here...
https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/raise-and-lower
If this doesn’t solve the issue, it sounds like there may be a custom dimmer curve set on those fixtures.
This will be due to the cue colour fade. To edit, view the playback the cue is programmed on by holding VIEW and tapping the playback’s button. Then tap on the colour time, which by default is 3 seconds. You can use the encoders to dial this to 0.
