Sean Posted December 5, 2020 Report Share Posted December 5, 2020 (edited) Hi Z88 I have three dimmers stuck 'ON' on a Chilli Pro bypass dimmer panel. Can I presume this is a triac issue or is there something else I should look for. Edited December 5, 2020 by Edward- Z88 Renamed topic, and moved to Power forum Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 5, 2020 Report Share Posted December 5, 2020 Hi Sean, Welcome to the Zero 88 Forum. 34 minutes ago, Sean said: Can I presume this is a triac issue or is there something else I should look for. Have you ensured that the preheat levels, and manual control levels, are set to their defaults? Apologies for checking the obvious, but have you ensured the bypass switch hasn’t been activated for the channels at full? If you have any questions let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
