Chilli Pro Bypass channels stuck on
Posted (edited)
Hi Z88
I have three dimmers stuck 'ON' on a Chilli Pro bypass dimmer panel. Can I presume this is a triac issue or is there something else I should look for.
Edited by Edward- Z88
Renamed topic, and moved to Power forum
  • Edward Z88 changed the title to Chilli Pro Bypass channels stuck on
Hi Sean,
Welcome to the Zero 88 Forum.
Expand
Have you ensured that the preheat levels, and manual control levels, are set to their defaults?
Apologies for checking the obvious, but have you ensured the bypass switch hasn’t been activated for the channels at full?
If you have any questions let us know.
