Craig Forrest Posted November 30, 2020 Report Share Posted November 30, 2020 Hi All, I currently have a dmx issue with a chilli 12-101 RCD dimmer, which is part of a chain of 7 individual dimmers. The dimmer in question is not recognizing the dmx signal and keeps displaying No Data. The transceiver chip has been changed both on the main PCB and on the key pad PCB, however the issues still persists. In addition when the dmx signal is connected to the board it also grounds/disables the dmx signal the the remaining dimmers. When the DMX is unplugged from the faulty board the remaining dimmers receive the DMX signal without issue. Has anyone came across this issue before and what are the likely causes? Thanks Craig Quote Link to comment Share on other sites More sharing options...
KWR88 Posted December 2, 2020 Report Share Posted December 2, 2020 Hi Craig, Believe i was talking with you at the end of October with regards to this. think we got to the point where we though it was the keypad cause the issue. From our mail trail, I offered to have a look at it you could send the card set back to me, but don't think that happened or if it did it may not have been direct from you as i cant see any further conversations. If you want PM me we can follow up on this. 1 Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
