Big Par 24x12 HEX RGBAW/UV stairville won't turn off with dimmer
   Hello, I've got an issue with the pars not turning off. When I switch down the dimmer lights doesn't completely turns off. Dmx output says channels are on 0 ( on z, system info, dmx output), still some light. Working with all other lighting solutions.
   They're working on 6ch but I don't have strobe effect. last update installed. Thank you !
  • 1 month later...
Actually if I turn the colors chanels to 0, light goes off. when the dimmer only is on 0, there is still some light.
If I clear the playback or the channel I have the dark, if I just use the fadder, it keeps randomly some light ( each time I up the fadder and go back down, the amount of light or color staying on the par is different)
I have only this problem, with this console. Works perfectly with all other consoles / controlers. Also, this problem happends with the 10 pars I've got of this kind.
