Mbmbmb31 Posted November 2, 2020 Report Share Posted November 2, 2020 Hello In new ZerOS 7.9.8 it seems there is no more effect proposed for a group of fixtures. Is it normal or due to a mistake from my own. Sorry if there is some mistake in my sentence, I’m french and I don’t speak english fluently . best regards Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 3, 2020 Report Share Posted November 3, 2020 Hello, 12 hours ago, Mbmbmb31 said: In new ZerOS 7.9.8 it seems there is no more effect proposed for a group of fixtures. Are you finding that if you select some fixtures, there is no "Effect" tab at the top of the internal touchscreen? If there is an "Effects" tab, are you able to press the "Automatically Create Effects Palettes" button in the effect window? 12 hours ago, Mbmbmb31 said: Sorry if there is some mistake in my sentence, I’m french and I don’t speak english fluently . Please don't apologise - your English is far better than my French! If you have any questions let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mbmbmb31 Posted November 3, 2020 Author Report Share Posted November 3, 2020 Hello, Thanks for your tolerance concernant my english. Are you finding that if you select some fixtures, there is no "Effect" tab at the top of the internal touchscreen? Yes There is an « effect » tab at the top or the internat touchscreen. If there is an "Effects" tab, are you able to press the "Automatically Create Effects Palettes" button in the effect window? Yes I can press the "Automatically Create Effects Palettes" button » but nothing happened. I have only one « no effect » button. To precise, for exemple I use a group of 4 motorized spots from DTS XR7 Spot 16 channels. But it’s the same with other group. With 7.9.7 I had several « effect » buttons like « triangle », « cercle »........ thanks for your help. Best regards Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 3, 2020 Report Share Posted November 3, 2020 Hello, 19 minutes ago, Mbmbmb31 said: Yes I can press the "Automatically Create Effects Palettes" button » but nothing happened. I have only one « no effect » button. Thank you for clarifying. I would recommend reinstalling your console's software. To do this, please download a fresh copy of ZerOS 7.9.8 from the website below... https://zero88.com/zeros#download Then extract the ZerOS 7.9.8.exe to the root of a USB stick, plug into the console, and tap Setup -> Load, and choose the software application to load in from USB. After installing the software, automatically creating effects should create 45 effects. Please try this and let me know how you get on. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mbmbmb31 Posted November 3, 2020 Author Report Share Posted November 3, 2020 Hello Sorry but I have to work on a new spectacle so I come back to the previous version. But I tried to do that on the last phantom ZerOS 7.9.8 and it’s the some. Best regards Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 3, 2020 Report Share Posted November 3, 2020 Hello, 53 minutes ago, Mbmbmb31 said: Sorry but I have to work on a new spectacle so I come back to the previous version. OK, when you are ready to install ZerOS 7.9.8, please download a fresh copy and perform the installation, and let me know how you get on. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mbmbmb31 Posted November 3, 2020 Author Report Share Posted November 3, 2020 Sorry but I already started to program a new spectacle with the previous version and I'm afraid of losing everything I've done by changing the version. But could you explain why it doesn’t work too on the phantom version. Michel Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 3, 2020 Report Share Posted November 3, 2020 Hi Michel, 40 minutes ago, Mbmbmb31 said: Sorry but I already started to program a new spectacle with the previous version and I'm afraid of losing everything I've done by changing the version. No problem. 28 minutes ago, Mbmbmb31 said: But could you explain why it doesn’t work too on the phantom version. If you saved a show on your console that only had a single effect palette, and load it into Phantom ZerOS, Phantom will just load the single effect palette. However, pressing Automatically Create Effects in Phantom will create the 45 auto effects. If it doesn't, please could you send me a copy of your show file saved in Phantom ZerOS that is not creating auto effects? Many thanks, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mbmbmb31 Posted November 3, 2020 Author Report Share Posted November 3, 2020 On the Phantom I did a show file test with only two group of fixture. you will found it joined. Michel show file test.zos Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 4, 2020 Report Share Posted November 4, 2020 Hi Michel, 19 hours ago, Mbmbmb31 said: On the Phantom I did a show file test with only two group of fixture. I have loaded your show file into Phantom ZerOS 7.9.8 running as FLX S48, and it loads with a single effect palette. Pressing Automatically Create Effect Palettes, then creates all 45 auto effects. I am therefore unsure why for you Phantom is only creating a single effect palette. On your FLX S48, please power cycle it, and then after rebooting please email me a picture of the Desk Info screen. This can be opened by pressing Z/Shift -> System Information. Then please choose "System Text" from the top, and please email me a picture of this screen too. Hopefully this will indicate why auto effects are not present on your console. If you have any questions let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mbmbmb31 Posted November 4, 2020 Author Report Share Posted November 4, 2020 Hello Edward infortunatly I can’t come back to version 7.9.8 on our FLX48. But, I did some experiences on phantom on my PC. I desintalled Phantom 7.9.8 and re-installed it from file extracted from Zero88 web site. After that I see in system information that the library version is 035. See photo 1. In this configuration, effects correctly works for my motorized spots. See photo 2 To continue my experience, I loaded the library version 1.00. See photo 3 Now the effects no more work. All previous one are now grey. See photo 4 When I pushed the « automatic create effect » button, all grey buttons disappear. See photo 5. To summarize, From my point of view the problem is more from library 1.00 than from 7.9.8 version. best regards Michel Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 4, 2020 Report Share Posted November 4, 2020 Hi Michel, 21 minutes ago, Mbmbmb31 said: I desintalled Phantom 7.9.8 and re-installed it from file extracted from Zero88 web site. 21 minutes ago, Mbmbmb31 said: To summarize, From my point of view the problem is more from library 1.00 than from 7.9.8 version. Thank you very much for your investigations. We have found that ZerOS Library v1.0 has auto effects missing, whereas they are included in Library 0.35, which is part of the ZerOS 7.9.8 download. Therefore when you are ready to, please download a fresh copy of ZerOS 7.9.8 from the website, and do not update the Library separately. We have removed the Library file from the website until we release a new version. Thanks very much, if you have any questions let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mbmbmb31 Posted November 5, 2020 Author Report Share Posted November 5, 2020 Hi Edward I re-loaded version 7.9.8 on FLX48 without library update. It works well. I will update the library when the new one will be available. Thanks for your help Michel Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 5, 2020 Report Share Posted November 5, 2020 Hi Michel, 30 minutes ago, Mbmbmb31 said: I re-loaded version 7.9.8 on FLX48 without library update. It works well. I will update the library when the new one will be available. Thanks for your help That's great. If you have any questions let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
