Stan Vigurs Posted October 19, 2020 Report Share Posted October 19, 2020 I'm using an FLX S48 with conventional dimmers and lighting fixtures. I need to insert a chase into a cue list and then stop this chase and revert to the next cue, which will be the same setting as the preceding cue. I have successfully created the chase and have inserted it as a macro after the relevant cue, but I cannot stop the chase running when moving to the next cue (or indeed any further cues). I've studied the User Manual but still can't fathom out how to do it. Help! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 19, 2020 Report Share Posted October 19, 2020 Hi Stan, Once your chase has been triggered, you will then need to tell it to release in the cue you would like the chase to stop. Therefore tap the Settings button of the cue you would like your chase to stop in. Then tap Macros... and add a playback to release. You can choose your chase playback, click OK, and then click OK on the settings window. When you go into this cue, your chase will then fade out, using the fade down time of the cue. I hope this helps, if you have any questions let us know. Edward Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
Stan Vigurs Posted October 19, 2020 Author Report Share Posted October 19, 2020 Thanks Edward, I'll see how that goes! Quote Link to comment Share on other sites More sharing options...
