norton Posted September 10, 2020 Report Posted September 10, 2020 Hello, I have one question to experienced with Zero flx s24: Is there a possibility to "blackout" channels/playbacks by one function, and then get back to light? I know the function hold Clear+playback - this I do when is chaos with effects and I need turn off. Is there something else how we can hold the dark and then back to the light? I really appreciated for answer, this is longstory problem with the ambivalance of the force in our theatre:) Thank You very much Norbert Quote
kgallen Posted September 10, 2020 Report Posted September 10, 2020 FLX-S does not have a dedicated Blackout button. But you can assign any unprogrammed MFF to be a blackout fader (and possibly can the button be a blackout button?). Any unprogrammed / clean MFF, use Setup on it and Blackout should be one of the options. (Sorry this is a bit vague, I have FLX with the dedicated button/fader). Quote
norton Posted September 10, 2020 Author Report Posted September 10, 2020 Thank you for quick reaction. It´s seems like only hack option.) Quote
Edward Z88 Posted September 10, 2020 Report Posted September 10, 2020 Hi Norton, Welcome to the Zero 88 Forum. As Kevin says, hold SETUP and tap an empty playback button, and choose Grand Master. The fader will then act as a Grand Master, and the playback's button will become the Blackout. With a single press of the playback's button, all intensities will go to 0, and a second tap will resume the intensities. If you have any question let us know. Edward Quote Edward Smith Product Specialist Email Support
norton Posted September 10, 2020 Author Report Posted September 10, 2020 I m sorry, but we have another lil case.) Function button View doesnt work standardly. No red light, and no reaction on internal display. Is there an option how to turn on Cue list and Playback Window. It dissapear. It´s a new think for us and it´s a twister! Thanks for your good-will! Quote
Edward Z88 Posted September 10, 2020 Report Posted September 10, 2020 Hi Norton, 10 minutes ago, norton said: Function button View doesnt work standardly. No red light, and no reaction on internal display. Is there an option how to turn on Cue list and Playback Window. It dissapear. It´s a new think for us and it´s a twister! On FLX S, the VIEW button will not light up. This is the intended behaviour. On FLX S24, pressing the VIEW button, should toggle the internal touchscreen between the Cues and Faders windows, when you are not in Setup. Holding Z/SHIFT and tapping VIEW will take you to the Output Window. Hope this helps, Edward Quote Edward Smith Product Specialist Email Support
norton Posted September 10, 2020 Author Report Posted September 10, 2020 10 minutes ago, Edward- Z88 said: Hi Norton, Welcome to the Zero 88 Forum. As Kevin says, hold SETUP and tap an empty playback button, and choose Grand Master. The fader will then act as a Grand Master, and the playback's button will become the Blackout. With a single button, all intensities will go to 0, and a second tap will resume the intensities. If you have any question let us know. Edward It´s seems very clever. Thank you very much. I will test it and confirm in next week! Quote
