RobTag Posted August 9, 2020 Report Posted August 9, 2020 Hi. I'm new to the FLX S48, so still getting used to what this system can do, but loving it. I have an external monitor attached and have a question regarding the Cues Playback window. When running a playback, the top window displays output of the lamps, as expected. The bottom window shows what cue is running, with fade times and cue stack (if programmed). Also as expected. My question is - when changing to another playback (ie. fade down MFF1 and fade up MFF2), the bottom window doesn't automatically update to the current selected playback. The only way I can change the display is to press and hold view and select the corresponding MFF button. Is there a way/setting so that the cue window automatically updates to the playback that has been selected? I hope this makes sense. Thanks Ciao Rob
kgallen Posted August 9, 2020 Report Posted August 9, 2020 Hi Rob, Welcome! I'm not aware of a setting to allow this. Edward will be along in a moment to correct me or offer a different solution! Kevin
Edward Z88 Posted August 9, 2020 Report Posted August 9, 2020 Hi Rob, 11 hours ago, RobTag said: Is there a way/setting so that the cue window automatically updates to the playback that has been selected? As Kevin says, choosing which playback you see in the Cues window, is a manual process of pressing and holding VIEW, and tapping the button of the playback you wish to view. This is to allow you to run cues on a playback, and temporarily overlay other lighting states from other playbacks without the cues window changing. Hope this helps, if you have any questions let us know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
RobTag Posted August 10, 2020 Author Report Posted August 10, 2020 Thanks - wishful thinking is was done automatically
