I have a question about Sunstrips style fixtures that use many DMX channels.
I could understand by talking with other technicians working on other consoles which using capacity like "Sub fixtures" to Using little  DMX channels, when many Sunstrips are used ...
When is it FLX and ZerOS, is it something that also exists?
Thanks for your help
Eric
Any "sub-fixture" support of a console is not going to change how many DMX channels are used. Number of DMX channels required is a function of which fixture features you want to be able to control from the console.
Sub-fixture support is purely about how the console presents the elements of a fixture on the UI and how it can use them in e.g. effects engines. No console "saves" DMX channels by supporting the concept of "sub-fixtures".
Hello
Thank for the answers.
So I see for exemples a LYRE LED PIXEL 19x15W RGBW which can use 95 CH DMX from LedStage.
If I want to have only 10 Lyre like this, it will use about 950 DMX Channels (2 universes) ...
So not so much easy to use projectors like this...
Have a good week
Eric
Hi Eric,
Yes, when you need to use fixtures in the high channel count modes, you will very quickly eat up universes when you are using a number of fixtures.
Hence why FLX is available up to 16 universes of DMX output for these large channel count situations.
This will be the case in all consoles, regardless of whether they have ‘sub fixtures’ or not.
Agreed that such beasts are likely to be easier to assimilate if the console does support a sub fixture concept.
To understand this better (having never used this kind of machine), can you tell me a bit about the advantage of having a console that can manage or not Sub fixtures?
Because if it does indeed change nothing on the side of DMX Channels, it takes an adventure to have Sub fixtures or not ...
Thank you very much for taking the time to explain this to me.
take care
Hi Eric,
”Sub-Fixtures” or “multi-part” or “multi-pixel” or”zoned fixtures”, basically means one fixture having potentially multiple intensities, multiple RGBW, or maybe multiple Pan and Tilt. The most common implementation of controlling such fixtures, is to use syntax such as 2.3. This would control part 3 of fixture 2.
Currently, we don’t have this functionality on ZerOS. All this means is you have a choice of how you control multi part fixtures on FLX.
Option 1, is you patch the fixture just like any normal fixture, where it just has a single fixture number on the console. However if there are multiple RGBW, these would just be under the colour attribute, and each time you tap COLOUR you would page through and access each part in turn. Doing this will not apply colour to the internal colour mixing, or effects. If there are multiple intensities, these are found under Beam.
Option 2, which is the best option if you are on FLX, is to patch each part/pixel as its own fixture. Therefore if you have a 10 cell LED batten, you wouldn’t simply have a single fixture patched on the console for the whole batten, you would have 10 pixels patched. You then have a fixture per pixel, and easily control them as whole by grouping them if you wish. If you’re on a FLX S console, you will quickly run out of fixture numbers using this method so you are best to elect for the full FLX in these situations.
So as Kevin mentions above, fixtures with multi-cell functionality typically use up more DMX channels, however the console can’t change that (unless you use RDM to change to a fewer channel count mode, but doing this would lose multi cell functionality).
If you are running out of DMX channels on your system, you will therefore have to put your lights in smaller channel count modes.
Hope this helps and makes sense, if you have any questions let us know.
Thanks Adward for the reply.
Question: ZerOS does not do this, but it will evolve. Because indeed there are more and more projectors which can work Led by Led, which implies to make matrix effects.
And you can see inexpensive solutions doing that.
So if I find that ZerOS is a really interesting software, there is also the evolution of the projectors and the needs of the people of the shows who evolve too.
So it is certain that ZerOS is evolving and this is positive. But it would be positive not to let other consoles take too many advantages on the FLX ...
Thanks in any case for your help.
Hello again,
I have a question, do you think that the management of matrix type devices could become something possible in ZerOS as for FLX?
thank you so much
Eric VDA
Hi Eric,
1 hour ago, van den abbeele Eric said:
Hello again,
thank you so much
Eric VDA
Yes, this is on our road map. Somewhere on the forum there are pictures of an early beta version of this on ZerOS.
Cheers
thank and good to know that !
  • 1 year later...
